Rasp Pi no teamviewer connection (stays in connecting)
Marc2173
Marc2173 Posts: 1
edited April 25 in Linux only
I´m useing PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
It´s online in the teamviewer program. I also can send a chat to the rasp pi. But if I start remote access --> connecting and nothing happens.
It tells my Wayland detected. But I don´t know how to handle this, if this is the problem. I add the log - hopefully it helps.
The Log-File:
2024/04/25 15:50:43.078 5426 5426 D  Logger started.
2024/04/25 15:50:43.079 5426 5426 D  Found 0 stack dump files ...
2024/04/25 15:50:43.079 5426 5426 D  Found 0 Minidump files ...
2024/04/25 15:50:43.085 5426 5426 D  systemd: logind service available
2024/04/25 15:50:43.088 5426 5426 D  systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='1', canGraphical=1, canTTY=1, canMultiSession=0]
2024/04/25 15:50:43.089 5426 5426 D  LogindSessionInfo: New session LogindSessionInfo [id=3 user=rasppool state=user active=0 reliable=1 infoId=1842515611] [path=/org/freedesktop/login1/session/_33 TTY=tty1 seat=seat0 display= vtnr=1 owner=[SysUser: rasppool [uid=1000, gid=1000 home=/home/rasppool gecos=,,, shell=/bin/bash]] idle=1(1714043821931999) active=0 type=tty class=user state=online timestamp=1714046679457690 service=login defaultCG= leader=1147 audit=3 remote=0 rHost= rUser= killProc=0]
2024/04/25 15:50:43.090 5426 5426 D  LogindSessionInfo: New session LogindSessionInfo [id=1 user=rasppool state=user active=1 reliable=1 infoId=2212294583] [path=/org/freedesktop/login1/session/_31 TTY= seat=seat0 display= vtnr=7 owner=[SysUser: rasppool [uid=1000, gid=1000 home=/home/rasppool gecos=,,, shell=/bin/bash]] idle=0(0) active=1 type=wayland class=user state=active timestamp=1714046668297259 service=lightdm-autologin defaultCG= leader=899 audit=1 remote=0 rHost= rUser= killProc=0]
2024/04/25 15:50:43.093 5426 5426 D  SysSessionInfoManager: observing sessions from logind is marked as reliable
2024/04/25 15:50:43.093 5426 5426 D  SysSessionInfoManager: Session Information provided by VT [priority: 2]
2024/04/25 15:50:43.093 5426 5426 D! FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2024/04/25 15:50:43.094 5426 5426 D  SysSessionInfoManager::SessionAdded: adding session WaylandSession: [SysSession 2212294583 [type=W vt=7 tty= pseudotty=0 info=1 id=1 user=rasppool state=user active=1 reliable=1]]
2024/04/25 15:50:43.096 5426 5426 D!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2024/04/25 15:50:45.099 5426 5426 D  Cannot acquire lock for "/run/user/1000/tv_desktop.lock", reason: locked by other process (4206)
2024/04/25 15:50:50.106 5426 5426 D  Shutting down DBus IOHandler
