Where do Session notes go?
bejoscha
bejoscha Posts: 2 ✭✭
edited May 1 in General questions
When a remote session is closed, TeamViewer pops up a dialog to as for comments on the connection with an text edit field to type in. On "Save".... where do these comments go? Are those comments to TeamViewer on the quality of the service, or comments for the user to remember the session? The dialog doesn't make this clear and I could not locate any comments I ever submitted like this.
  • Solutions4
    Solutions4 Posts: 17 ✭✭
    edited May 1 Answer ✓
    They are visible in the TeamViewer portal (web interface) under device groups, connection reports. There you can view the connections you make. Note this feature can also be turned off if not required.
  • Solutions4
  • bejoscha
    Thanks, one riddle solved.
    (Nothing there on my interface, but it says I'm lacking permissions by the administrator.)
  • Solutions4
    On your PC someone will be required to edit using the administrator username and password.
    Happy to help. It is a minefield.
