files transfer error(teamviewer12)
Hello!
teamviewer12 always shut down when I try to transfer files .
after I print IP and password , teamviewer12 just shut down and show error message
like this:
Can anyone tell me how to fix it ?
I really need this function.
Hello simonhahaha,
I can't read what that message is saying, could you translate it for me? Maybe i could help you with this problem!
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0 -
THX bro I try my best to translate . Hope everyone can understant it . The biggest blue color sentence TeamViewer12 已經停止運作 . it's mean TeamViewer12 has stopped working . And in the first picture , Windows正在尋找問題的解決方案 . it's mean Windows is looking for a solution to the problem . in the second picture . the long sentence with black and small font . the roughly meaning is " there is a problem caused the program stoped working . Windows will shut down the program and notice you when there's a solution" .0
Hello simonhahaha,
How fast is your computer and is there a big program running in the background that could couse teamviewer to crash? If so you should shut down the program thats taking a lot of Ram memory of your computer so teamviewer can run again!
I hope this helps,
Iain Wels,
ICT-Support
sorry , my description is not clear. let me clarify this situation again .
In few month ago . I can still use file transfer . but recently this function always cause error .(like my word before)
And I try to find out what's happen . so I test file transfer in some different IP .
I notice that there is one of it can still work . but others cause Teamviewer12 crash .
I can't find the reason why suddenly file transfer can't use and why specific IP can still transfer file .
so I doont't think this is computer problem because I can use file transfer before .
Is there any probably reason or anyone has same problem ?
because I search this web site and find nothing .
