Teamviewer 12 wont open UI
Teamviewer 12 on manjaro cinnamon 17 wont open the UI or start. Version number is 12.0.850001-6.
Logs I will attach and can only see error 140.
2017/10/12 19:32:10.430 15392 139953886943232 gX0 Logger started.
2017/10/12 19:32:10.432 15392 139953886943232 gX0 Found 0 Minidump files ...
2017/10/12 19:32:10.432 15392 139953886943232 gX0 Found 0 core dump files ...
2017/10/12 19:32:10.433 15392 139953886943232 gX0 systemd: logind service available
2017/10/12 19:32:10.435 15392 139953886943232 gX0 systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='1', canGraphical=1, canTTY=1, canMultiSession=1]
2017/10/12 19:32:10.435 15392 139953886943232 gX0 SystemdSessionInfo: New session SystemdSessionInfo [id=1 user=corin state=user active=1 reliable=1 infoId=0] [path=/org/freedesktop/login1/session/_31 TTY= seat=seat0 display=:0 vtnr=7 owner=[SysUser_Lin: corin [uid=1000, gid=1001 home=/home/corin gecos=cpb shell=/bin/bash]] idle=0(1507783883059195) active=1 type=x11 class=user state=active timestamp=1507705435332065 service=lightdm-autologin defaultCG= leader=887 audit=1 remote=0 rHost= rUser= killProc=0]
2017/10/12 19:32:10.435 15392 139953886943232 gX0 SysSessionInfoManager: Session Information provided by systemd [priority: 0]
2017/10/12 19:32:10.435 15392 139953886943232 gX0 SysSessionInfoManager: Session Information provided by VT [priority: 2]
2017/10/12 19:32:10.436 15392 139953886943232 gX0 XSocket observer: watching /tmp/.X11-unix
2017/10/12 19:32:10.436 15392 139953886943232 gX0 XSocket observer: adding XSession: 0
2017/10/12 19:32:10.466 15392 139953886943232 gX0 SysSessionInfoManager: assigned session 0 to info provider 'systemd'
2017/10/12 19:32:10.466 15392 139953886943232 gX0 SysSessionInfoManager: assigned session 1000000 to info provider 'None'
2017/10/12 19:32:10.469 15392 139953886943232 gX0 Initialised XFixes extension (base=87 error=140)
2017/10/12 19:32:10.469 15392 139953886943232 gX0 TVGuiSlave.64: Running
2017/10/12 19:32:10.441 15393 4108466176 QX0 Logger started.
2017/10/12 19:32:10.443 15393 4108466176 QX0 Found 0 Minidump files ...
2017/10/12 19:32:10.444 15393 4108466176 QX0 Found 0 core dump files ...
2017/10/12 19:32:10.444 15393 4108466176 QX0 systemd: logind service available
2017/10/12 19:32:10.446 15393 4108466176 QX0 systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='1', canGraphical=1, canTTY=1, canMultiSession=1]
2017/10/12 19:32:10.446 15393 4108466176 QX0 SystemdSessionInfo: New session SystemdSessionInfo [id=1 user=corin state=user active=1 reliable=1 infoId=0] [path=/org/freedesktop/login1/session/_31 TTY= seat=seat0 display=:0 vtnr=7 owner=[SysUser_Lin: corin [uid=1000, gid=1001 home=/home/corin gecos=cpb shell=/bin/bash]] idle=0(1507783883059195) active=1 type=x11 class=user state=active timestamp=1507705435332065 service=lightdm-autologin defaultCG= leader=887 audit=1 remote=0 rHost= rUser= killProc=0]
2017/10/12 19:32:10.446 15393 4108466176 QX0 SysSessionInfoManager: Session Information provided by systemd [priority: 0]
2017/10/12 19:32:10.447 15393 4108466176 QX0 SysSessionInfoManager: Session Information provided by VT [priority: 2]
2017/10/12 19:32:10.447 15393 4108466176 QX0 XSocket observer: watching /tmp/.X11-unix
2017/10/12 19:32:10.447 15393 4108466176 QX0 XSocket observer: adding XSession: 0
2017/10/12 19:32:10.493 15393 4108466176 QX0 SysSessionInfoManager: assigned session 0 to info provider 'systemd'
2017/10/12 19:32:10.493 15393 4108466176 QX0 SysSessionInfoManager: assigned session 1000000 to info provider 'None'
2017/10/12 19:32:10.494 15393 4108466176 QX0 TVGuiDelegate: Running
2017/10/12 19:32:10.601 15392 139953886943232 gX0 TVGuiSlave.64: Terminated
2017/10/12 19:32:10.601 15393 4108466176 QX0 TVGuiDelegate: Terminated0
