[Windows] v15.58.4
Operating system: Windows
Version: 15.58.4
Release date: 2024-09-24
New features
- Users can now select how they want to work with devices. An additional "basic" view is now available, which allows users to view all their groups and devices at one glance, without tab-switching.
- It is now possible to create custom Android Host modules via admin settings. This will streamline the assignment process and avoid the need to share credentials when managing a device.
- It is now possible to initiate editing of a device, device group, or contact via the Global search results.
Improvements
- Starting in October, Free users will be upgraded to the new interface, giving them access to our latest features and enhanced security. Licensed users can continue connecting with Free users using their preferred method. Learn more.
- It is now possible to create and manage custom Android Host modules. The custom module can be linked with a rollout configuration, which allows you to define various configuration options for your deployed managed devices.
- Free users will now be able to view groups that "require migration" in TeamViewer Remote.
- It is now possible to select the "Inherit from group" policy option for single or multiple devices within a managed group.
- The "It's you" pill now has the correct color.
- The "Assigned to You" pill is now the intended color.
- Improving signature verification for Windows drivers. (Security Bulletin: TV-2024-1006)
Bugfixes
- The "Add users to role" dialog now includes a vertical scrollbar.
Posted from discussion at: https://community.teamviewer.com/English/discussion/136943/windows-v15-57-5#latest
JeeveStobs
13
Faulting application name: TeamViewer.exe, version: 15.58.4.0, time stamp: 0x66e9e29f
The latest TeamViewer version crashes when opening a Windows shortcut of a LAN-only device:
Faulting module name: KERNELBASE.dll, version: 10.0.19041.4842, time stamp: 0xe6d00f33
Exception code: 0xc000041d
Fault offset: 0x000000000003b699
Faulting process id: 0x3bc0
Faulting application start time: 0x01db0ec6b235c439
Faulting application path: C:\Program Files\TeamViewer\TeamViewer.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 448dd107-a338-47e3-8f37-3d7708e46679
Faulting package full name:
Faulting package-relative application ID:The TeamViewer Windows shortcut is simply the following:
"C:\Program Files\TeamViewer\TeamViewer.exe" -i 192.168.1.2 -- Password $password"
Any chance we can get this fixed in the next update?
4 -
We also experience this.
When TeamViewer is closed and we use the command, then one log is recorded in the Event Viewer:
Faulting application name: teamviewer.exe, version: 15.58.4.0, time stamp: 0x66e9e29f
Faulting module name: KERNELBASE.dll, version: 10.0.22621.3958, time stamp: 0xfbc3a4f6
Fault offset: 0x000000000005fabc
Faulting process id: 0x0xE21C
Faulting application start time: 0x0x1DB0FEFB974C3E8
Faulting application path: C:\Program Files\TeamViewer\teamviewer.exe
Report Id: 0d4d46d5-2673-474d-b1ee-7aa2a7c646c7
Faulting package-relative application ID:I tried opening TeamViewer and run the commands again. Then I got 2 log entries:
Exception code: 0xe06d7363
Faulting process id: 0x0xADB4
Faulting application start time: 0x0x1DB0FF0D6396940
Report Id: d61ba409-5efe-4227-b246-825011532efe
Faulting package-relative application ID:and then 3 seconds later
Report Id: e33c6c09-f2b1-4d13-8218-d512f5614abb
Faulting package-relative application ID:We use the program Remote Desktop Manager to execute the commands.
3 -
Having exactly same problem :( It is impossible start remote connection via command line.
2 -
We are having the same problem with LAN shortcuts or command line.
Same on 64 or 32-bit.
Faulting application name: TeamViewer.exe, version: 15.58.4.0, time stamp: 0x66e9de03
Faulting module name: KERNELBASE.dll, version: 10.0.22621.4111, time stamp: 0xb2651143
Fault offset: 0x0014a892
Faulting process id: 0x0xA068
Faulting application start time: 0x0x1DB104511E6EF96
Faulting application path: C:\Program Files (x86)\TeamViewer\TeamViewer.exe
Report Id: [removed per Community Guidelines]
Faulting package-relative application ID:3 -
Same issue for everyone in our org.
"C:\Program Files\TeamViewer\TeamViewer.exe" -i XXXXX
2024/09/27 10:18:01.496 57144 70216 G2!!!CRASH: Unhandled C++ exception at 00007FFF1914FABC: Type unknown (Exception Code: 0xE06D7363)
2024/09/27 10:18:01.504 57144 70216 G2!!!CRASH: Starting process to save dump file as 'C:\Users\user\AppData\Local\TeamViewer\Logs\TeamViewer_15_58_4_x64_20240927T101801.mdmp'2 -
Same thing here. Very annoying…
Same here, my whole support team is broken. Because of that feature stopped working. I`m serching where to find the previous verion to downgrade and resume bussines as usual!
Thank you for bringing this issue to our attention.
Our teams are aware of it and are doing their best to investigate and resolve it. We will update this thread as soon as we have more information.
We apologize for any inconvenience this may have caused and appreciate your patience and support.
Jen
We are having the a similar issue using command line parameters example:
TeamViewer.exe -i 123456789 -p example1234
The logs shows a "TeamViewer terminated unexpectedly" error. I have contacted support too, so hopefully it can be fixed soon.0 -
I have contacted support too, so hopefully it can be fixed soon0 -
Since the update, many of my managed devices are showing as online (Green), but they are not.
2
