QucikSupport - comments not visible in Management Console
Is there any propagation time (I must wait few minutes) , or Comments from QuickSupport Sessions are not visible in Management Console.
mLipok , AutoIt MVP
  • mLipok
    mLipok Posts: 774 ⭐Star⭐
    REMARK: when I connect to the same host but via standalone APP then all comments are visible immediately.
    mLipok , AutoIt MVP
  • mLipok
    Oh.. thanks, my fault.
    I just now (thanks to you) noticed that there are separate "Connection logs".
    The other question is: Which function in TeamViewerAPI can get a list of these connections ?
    mLipok , AutoIt MVP
  • Jonathan
    Jonathan Posts: 243 [Former Staff]
    Hi mLipok,
    Thanks for your reply!
    Please checkout the following link to see if it answers your questions regarding viewing your connections in TeamViewer API.
    https://integrate.teamviewer.com/en/integrate/reporting/
    Hope this helps!
    Jonathan
  • mLipok
    On a first glance, it seams that I used only "Reporting" Feature (Chapter 3.6) but I should also use "Sesion Management" Feature (Chapter 3.5).
    I will try it next week, and back to this thread with results.
    mLipok
    mLipok , AutoIt MVP
