New interface only shows an empty, white window when TeamViewer loads
TeamViewer has been badgering me to use the new interface quite a lot recently. My problem is that I am simply unable to use the interface as it just will not load.
When I open TeamViewer, all I see is a white, empty window. Reading online, this appears to be some sort of Microsoft Edge issue, so I have ensured that MS Edge is up-to-date.
I am forced to edit a registry key to restore the old interface, which simply isn't good enough.
Can somebody please help me get the new interface working? It seems TeamViewer is adamant that we all use it for some reason, so I need this fixing.
  • Bronwhou
    Bronwhou Posts: 6
    Answer ✓
    Just an update to this thread out of courtesy.
    As somebody who uses primarily uses Firefox as my web browser, I don't use Edge. Therefore the lack of using Edge stopped Edge updating itself. After updating Edge and WebView2, TeamViewer loaded with the new interface - where I quickly changed back to the classic 'old' interface, which clearly doesn't suffer from the new interface's dependencies.
