No recovery code to deactivate or change two-factor
Jason
Jason Posts: 1
edited November 2024 in General questions
I enabled two-factor authentication after my TeamViewer account was hacked into last year. It worked fine for a while, but I have changed phones and I can not enroll a new authenticator nor deactivate two-factor without my old phone, which was already wiped and sold. Unfortunately I must not have paid attention when the two-factory recovery code was given. How can I regain full access to my account?
I am still authenticated to multiple devices if that helps to prove my identity, and I also have access to my email. I had to create a new account to join the community and post this message since I could not log into the old one via the website.
I think that email or SMS authentication would be a much better backup method for account recovery than the method currently used.
Best Answers
    JeanK Posts: 7,070 Community Manager 🌍
    edited November 2024 Answer ✓
    @Animesh
    There are two options you can follow to get you started again:
    If you own a professional TeamViewer license:
    • Please contact our support via phone, they will guide you through the procedure: Contact us via phone
    If you are using the free version of TeamViewer:
    • You can create for free a new account: https://login.teamviewer.com/LogOn#register
    • If creating a new account with a different email address is not an option and you want to use this same account again, you can request the deletion of your TeamViewer account by writing an email to privacy@teamviewer.com.
    • As soon as the account is deleted by our dedicated team, you will be able to create the TeamViewer with this same email address.
  • JoshP
    JoshP Posts: 905 Senior Moderator
    Hello @Dmdrl
    Thank you for your post, and welcome to the TeamViewer community!
    The first thing I would suggest is to take a quick look in your downloads folder - At the end of the setup for two factor authentication, you are prompted to save the recovery key - one option is to download a txt file:
    I bring this up as I was in your situation recently, and as a last resort I searched my downloads folder (which I never clean out... I know, I know...) but lo and behold - it was there! The filename is:
    TeamViewer_recoverycode.txt
    If, however, we are unable to locate the recovery code, then there would be no way to disable two factor authentication. As mentioned in our article on how to deactivate two factor authentication:
    CAUTION: The Two factor authentication can not be deactivated by TeamViewer. If you lose your recovery key, you will also lose access to all TeamViewer features where your account is needed. Therefore, it must be kept in a secure place.
    As mentioned by our Community Manager @JeanK there are a couple potential solutions which depend on the version of TeamViewer used:
    Should you have any other questions regarding this, please do not hesitate to let us know.
    Take care!
    Josh P.
    Senior Community Moderator
  • JenW
    JenW Posts: 1,268 Senior Moderator
    Hi @JimmyRow,
    Welcome to the TeamViewer Community ! 🌍
    First, could you please check if you have saved somewhere the recovery code when you activated TFA?
    If you don't retrieve this recovery code, as a free user, there are two options you can follow to get you started again:
    • You can use this brand-new TeamViewer account with your old email address.
    • If this option above is not optimal for you, you can request the deletion of your TeamViewer account by writing an email to privacy@teamviewer.com. As soon as the account is deleted by our dedicated team, you will be able to create the TeamViewer account with this same email address.
    Let us know if you have any further questions, we will be happy to assist you!
    Jen
«1
  • I have the same issue. I can still access my account as I'm authenticated on my laptop via the app. How do I go about getting two factor deactivated without the recovery code?
  • spkack
    spkack Posts: 2
    My phone is broken and is not recoverable.  Was using Google Authenticator to access Teamviewer with 2FA.  I do not have the recovery code.  This is not my real account since I had to set this up to post here.  From my research looks like my original account will need to be deleted.  Can someone assist me with this please?  Thanks so much!
  • kevy007
    kevy007 Posts: 2
    Hi team,
    I have lost my recovery code and my mfa. I dont think there is a way around this other than getting in touch with you guys? Our company Admin said there wasnt much they can do either.
    Your help is appreciated.
    Kevin
    Credit Sense
  • Animesh
    Animesh Posts: 1
    I lost my recovery code . Kindly help getting it back
    @Animesh
  • Duythuong
    Duythuong Posts: 1
    i used to use 2 step auth but now i change iPhone. Now i dont have QR code and recovery key. How can I reset it?
  • rhayman
    rhayman Posts: 2
    Good morning,
    A few days ago this option in Temviewer stopped sending me a push notice to my approved device on all of the PC’s I remote into.
    I removed my device on all of my remote PC’s thinking it was a temporary issue.
    But the problem has lasted for several days now.
    I tried deleting and re-adding my approved device. But that didn’t help.
    Am I doing something wrong? Or is there an issue on your end?
    Thank you.
    Robert L.
  • hzp90
    hzp90 Posts: 4
    If I forgot my recover code and can not log in so how can I delete my account?
  • John_
    John_ Posts: 1
    So, two questions asking the same thing, but no answers? I have the same issue and thought I would get an answer by clicking on a previous topic with the same issue - how wrong was I.
  • bperez77
    bperez77 Posts: 2
    My phone recently broke and I unfortunately lost access to my 2FA method via the authenticator app. Additionally, I forgot to record my recovery codes. I've read a few other discussions on the forums and my understanding is that the only way to reset the account is to delete it completely and then re-register. Can I request to have my account deleted completely?
  • Raveen
    Raveen Posts: 2
    The previous authenticator app was reset and the backup was deleted. I do not even have team viewer recover codes. How do I recover it?
  • Tiny_Tyman
    Tiny_Tyman Posts: 3
    I am in need of some assistance. When I configured my TeamViewer account some time ago, for the sake of security, I enabled 2 Factor using Google Authenticator. Today, while using my Google Authenticator, I had it glitch up on me, in which it was showing duplicates of my account codes. When I tried to clear out those duplicates, I ended up losing the 2 factor code that goes to my TeamViewer account. I do have my recovery code fortunately, but apparently to disable my 2 Factor, I have to already have the code to enter in.
    Any help on this would be greatly appreciated! I would prefer to not have to make a new account account all over again.
    Thanks,
    Tyler J Turnbull
  • byeongchae
    byeongchae Posts: 2
    I lost my two-factor authentication recovery code.
    Is there any way to solve this?
    No matter how much I searched, I couldn't find it.
  • Scofreyjet_58
    Scofreyjet_58 Posts: 2
    I was trying to set up a laptop for unattended access, and it asked for a 6-digit code. I don't remember setting up for 2FA, and none of my authenticators have TeamViewer listed. When I say I can't access the code, it asked for a Recovery Code, something else I don't have.
    I tried to set up 2FA using Google Authenticator, but it says it can read the code that is displayed.
    Is there any way I can save this account, or am I going to have to abandon it and start all over with a different email account?
  • darknetcs
    darknetcs Posts: 2
    Hi
    My phone crashed and whipped all my 2FA codes, also I've lost all my data on my NAS where I kept my recovery codes (well just my luck), now while I'm still logged in to TeamViewer on my main computer I can log into Management Console, but cannot obtain recovery codes, as they are locked behind 2FA, nor cannot deactivate 2FA for same reason. Can anyone advise me what to do please?
  • AndyfromFL
    AndyfromFL Posts: 1
    My account apparently has two factor authentication on it. I'm afraid that my account might have been compromised, since I've only got one authenticator app and team viewer isn't on it. I doubt it's possible that I set it up, but even if I did, I don't have access to it or a backup code. Is there any support option to sign into my account, or am I forced to make a new account?
  • James7856
    James7856 Posts: 4
    I forgot where to get my security code and tried to sign in with my recovery code. But it doesn't work. How can I get back to my account? Thanks!
  • lepixa1226
    lepixa1226 Posts: 2
    Good morning,
    I have lost access to the OTP code needed to log into my TeamViewer account. How can I reset two-factor authentication to log back into my account?
  • cdwilkins1
    cdwilkins1 Posts: 2
    I need to remove MFA from my account. Due to this being tied to Google Auth and not having access to that app on another device, and the device having been wiped I can no longer log into my account.
  • Reshans
    Reshans Posts: 2
  • Mrrazorb
    Mrrazorb Posts: 1
    Desperate need of turning off two factor auth, i do not have my security code as it was stored along with my authenticator on a phone that was destroyed.
    Want to remove and then reinstall it.
    Please help
  • Dmdrl
    Dmdrl Posts: 3
    Hello!
    The recovery code for disabling two-factor authentication has been lost. The device used for this is also unavailable
    What can I do in this situation?
  • JoshP
    Hello @Dmdrl
    Take care!
    Josh P.
  • Dmdrl
    Dmdrl Posts: 3
    Hello @JoshP !
    Thanks a lot. Indeed, I did not find a file, but a screenshot with that name.
    Thank you again!!!
  • JoshP
    Thanks for the update @Dmdrl!
    I am glad to hear that worked for you as well!
    I hope you have a great rest of your week!
    Josh P.
  • dresq
    dresq Posts: 2
    Hi - if you've misplaced your recovery code and your 2FA is no longer in your authenticator (new phone / can't recover), is there a way to at least delete your account so that the now-inaccessible account is no longer paired to the email address with which it was created? Thanks!
  • JoshP
    Hello @dresq
    Thank you for your post, and we are pleased to welcome you to the TeamViewer community!
    I have included the most relevant information for you from the linked comment from @JeanK, our Community Manager:
    I hope this helps!
    Josh P.
  • jamesd3rd
    jamesd3rd Posts: 2
    A user where I work has a TeamViewer account that uses two Factor authentication. In the past year or two she got a new phone but didn't fully set up the TeamViewer account in the authenticator app on the new phone. When she taps on the TeamViewer entry on the authenticator app she gets prompted to recreate the account. It says the account is disabled an to add it again. Which cannot be done unless you sign into TeamViewer and scan the QR code using the phone. The only way you can do that is by entering the six digit code. At this point we have to deactivate two-factor authentication, delete the TeamViewer entry from the authenticator app on the old phone (if that's still possible), and add it to the new phone by scanning the QR code in the TeamViewer account.
    I should mention that throughout all this, she had forgotten her TeamViewer password so she reset it using the browser. Part of the process requires entering these six digit code that you get from two-factor authentication which she unable to get per the previous paragraph. She has a copy of the recovery code so she entered that in the authenticator app that's on the new phone and the app created a two-factor authentication code but for some reason, TeamViewer would not accept any of the two-factor authentication codes generated when she tried to complete the reset password process.
    So now we're stuck kind of in limbo. Unable to complete the reset password process because there's no valid six digit code coming from the authenticator app after she entered the recovery code which prevents her from deactivating to factor authentication.
    What course of action is there now?
  • CBoulenger
    CBoulenger Posts: 3
    I learned that it isn't possible to remove MFA, so the account will need to be deleted.
    Thanks forum!
