Portes of teamviewer
Hello everyone!
I connected through a filtered internet provider so I have a lot of problems with the feature.
I would be happy if you could provide me with the list of addresses / sites / ports that the software should use, which I will send to a company that will open them to me freely and it will help me very much.
Thank you all !!!
[personal information removed by moderator]
  • Chiron
    Chiron Posts: 229 ✭✭
    Which-ports-are-used-by-TeamViewer
    • TCP/UDP Port 5938 is preferred.
    • TCP Port 443 is tried next.
    • TCP Port 80 is a last resort.
  • michael3
    thank you for the answer!
    I've already seen this post, but it does not help me.
    I need to know URL of sites (WWW.?.COM) to open them for good.
    Thanks for the help
    Waiting for an answer
    Michael
