Hi. Every time after I use team viewer, the app keeps signing out. Next time I use the app again I have to sign in once again.
Can I stay signed in for a longer period of time even if I close the app after using it? Thanks.
We're aware of an issue that caused the "stay signed in" feature to not work as expected in some cases. We rolled out a fix for this today. Our apologies for the inconvenience.
Our team is also working on some other issues that have been reported, with TeamViewer being signed out unexpectedly.
Note that if your company uses Single-Sign-On, the sign-in duration is set by your corporate policies.
I'll keep you updated as soon as we have more to share.
We thank you for your patience and trust as we work to fix the issue as soon as possible.
/JeanK
Hello together,
Thank you all for your messages.
We forwarded you cases to our development department, which has confirmed that they are working on it.
Please keep your TeamViewer client updated to ensure you do not miss the fix as soon as it is available.
You'll find all Changelogs here: Changelogs
We are very sorry for any inconvenience. If you have any questions about TeamViewer or need more information, please feel free to contact us again.
Best, Nadin
got same on latest version - after 14 work good - will recheck but think it was latest;
and today on his own start autologout remote PC user after close TV window (connection); (before got strange autolock or logout on main PC too);
pls explain is TV team do wrong or hacked //// ?????
or it's windows on his own added gp rules etc ????
try set TV setting on remote to never (but still autologout) - prev. had autolock auto on remote and it never lock it.... and now looks like TV-team decided to autologout all without any notify and option to set it back ... [removed per Community Guidelines].
I can switch to **Third Party Product** but TV you lost users on such stupid things... it's very wrong politics.....
Any updates to this? I'm experiencing the same issue.
Thanks JeanK,
64 Bit,
FYI, The current version I am on and still getting logged out is 15.40.8 3/22/2023.
Have a good day.
Hi @JSS51,
I'll touch base with our dev team to check the best troubleshooting method.
Did you install the 32-bit or the 64-bit TeamViewer version on the impacted device?
Hi Jeank,
I attempted your suggestions and my Teamviewer Client still signs out after 1-7 days on this recently purchased Windows Laptop.
I have also made google searches to keep TV from auto signing off. So in addition I have also:
turned off (Internet Protocol Version 6 (tcp/ipv6) but this hasnt made any improvement.
Any other options I can try?
Welcome to the Community!
This could be something related to the login cache not being saved properly.
I'd recommend:
HI all,
I have 3 totals TV clients and and an issue with my TV Client running on my Windows 11 Home version (build 10.0.2261). The issue is my TV Client keeps signing itself out after a day or two. I don't see that my Laptop has rebooted when this occurs. If I bring up the TV app I just have to click on the login prompt and it logs back in successfully.
My other two older Windows Devices running the same version of TV 15.39.3 are working perfectly. Any thoughts on what I can check to keep TV from signing out?
