Windows 10 fall creato update
Johnblack
Team Viewer not working after update. No remote connection. The connection procedures starts then is blocked with "parameters view initialization " message (in italian - this is a translation) . Remote connections from the same PC with other PCs working correctly
Same thing. After Fall Creator update TeamViewer stopped to work - doesn't connect to remote computers. Message "Unable to connect. Unknown reason".
Re-install didn't help. Fiewall options look same as for other computers.
