Could it be possible to use multi user inlog (on a windows server)
We would like to use the server system by two different users at the same time, each with it's own desktop and own teamviewer session.
could this be possible?
Hello @Wartburg,
Thank you for your reply.
Understood. The option here would be to use the Server ID and UAC.
TeamViewer is able to connect to different Windows sessions using the unique User ID that is created for every active Windows session. For this to work, the Windows session must be active with a user being logged in. Otherwise, the ID will be shown as offline.
To connect to the device without the need for an active Windows session, we suggest using the Server ID. In this case, it is important to note that when a second user connects via Server ID, they will be connected in the first user's active session.
Here is our Knowledge Base article on Connecting via Windows Authentication to control UAC during a TeamViewer session. There we provide all instructions to connect using Windows Authentication.
Hope these work out! Please let us know how it goes😊
Elif
I understand indeed the serverID en user ID.
Could we connect to the userID without the user logged in at the windows session? (now it seems the ID appears to be offline)
At the moment we only have the serverID active and if a second users will connect he will come to the screen of the first user. And has to disturb the first user before a second user session could be activated on the windows server, after they can connect each to the cliendID.
We want to make multiple connections with the same pc and use different desktops, without someone always be logged in.
like we make connections with our windows credentials (TeamViewer) and will go to the desktop of that user (windows session). And the second user will got to his desktop as well.
Thank you for your reply!
Yes, as also mentions in our article, if you are using the Full Client module, you can click on the TeamViewer logo in your Task Bar and choose About TeamViewer, you will always be able to see both the User ID and the Server ID there:
If you are using the Host module, after connecting with your TeamViewer ID, please click on Show Server ID button as shown below:
Then, the Server ID will be shown like this:
The Server ID is always online as long as there is a TeamViewer service running, and TeamViewer on a server is only supported with the running service.
Hope these are helpful! Let us know if you need further assistance.
Wishing you a great day!
thanks, for your message,
I did try and find out that when the user is logged off the ID will disappear.
could it be possible to leave the ID active also when the user is logged out?
Welcome to TeamViewer Community!
Yes, that is totally possible!
To quote from our Knowledge Base article Use TeamViewer Remote on Windows Servers:
Using TeamViewer Remote on Windows servers will generate an individual TeamViewer ID for every user who connects to the server using Remote Desktop (RDP) by Microsoft as well as for the physical console. Therefore, parallel and individual work in each session is possible.You will get two different IDs: the Server ID and the User ID.
Our article will guide you through all the details, with IDs and modules explained clearly.
Please let us know if you need further assistance, we would be happy to support you.
Have you heard?! On October 21, we’re hosting TeamViewer Rise—and we want to see you there! The digital event dedicated to IT experts. Join us to hear industry leaders as they share demos, roadmaps, and real-world strategies for delivering better IT. Take part in our first annual event for Proven, ready-to-deploy…
