teamviewer 12 for linux antergos no opening
engelsp
engelsp Posts: 3 ✭✭
Hi
a few days back my teamviewer does not load the gui interface i have reinstalled it and still doesnt work.
my version is 12.0.85001 i found this error in the log file. Thanks in advanced.
2017/10/10 13:41:22.359 8 9 GX0!! MachineHooks: Library not found, Errorcode=126
2017/10/10 13:41:22.359 8 9 GX0!!!CRASH: Access violation at 0x7eb14a69: Illegal read operation at 0x00000004 (Exception Code: 0xC0000005), Errorcode=1400
2017/10/10 13:41:22.568 8 9 GX0!!!CRASH: Saved dump file to '/home/engels/.local/share/teamviewer12/logfiles/TeamViewer_12_0_85001__20171010T134122.mdmp'
2017/10/10 13:41:22.590 8 31 GX0 ProxySearch: no PAC script detected via WPAD
2017/10/10 13:41:22.607 5574 4116871104 QX0 TVGuiDelegate: Parent terminated
2017/10/10 13:41:22.637 5573 140041045354496 gX0 TVGuiSlave.64: Parent terminated
2017/10/10 13:41:22.637 5573 140040495691520 gX0 PulseAudio: Exit main loop (0), err=-2
2017/10/10 13:41:22.638 5573 140040732485376 gX0 XClipboard: Shutting down event loop
2017/10/10 13:41:22.707 5574 4116871104 QX0 TVGuiDelegate: Terminated
2017/10/10 13:41:22.717 8 28 GX0 TVW ReadSlave [1]: Socket closed
2017/10/10 13:41:22.717 8 28 GX0!!!WineGuiMaster[1]: Slave terminated unexpectedly, Errorcode=87
2017/10/10 13:41:22.717 8 28 GX0! TeamViewer.exe: unable to send command 2
2017/10/10 13:41:22.738 5573 140041045354496 gX0 TVGuiSlave.64: Terminated
2017/10/10 13:41:22.741 8 26 GX0 TVW ReadSlave [0]: Socket closed
2017/10/10 13:41:22.741 8 26 GX0!!!WineGuiMaster[0]: Slave terminated unexpectedly, Errorcode=87
2017/10/10 13:41:22.742 8 26 GX0! TeamViewer.exe: unable to send command 2
2017/10/10 13:41:22.804 8 31 GX0 ProxySearch: no PAC script detected via WPAD
2017/10/10 13:41:24.173 8 23 GX0 InterProcessBase::SecureNetworkCallbackHandle created (RegistrationID: 4bda3571-71de-4a2c-811f-f386e2f69fe5)
  • adsadasd
    adsadasd Posts: 1
    This is GOLD Jerry, GOLD :D
    It worked for me, took the lib from here:
    https://packages.debian.org/stretch/i386/libfreetype6/download
  • DarkoV
    DarkoV Posts: 1
    I've had the same problem on Debian Buster. This was a solution! Thank you!
  • rowbot
    rowbot Posts: 2 ✭✭
    can you be more specific please?
    i dont have pacman installed or yaourt - how do you install these?
  • landy
    landy Posts: 1
    Go to this page and download the deb file.
    Then extract it.
    sudo dpkg -x filename ./extracted-file
    Then copy files from extracted-file/usr/lib/i386-linux-gnu
    to
     /opt/teamviewer/tv_bin/RTlib
    Then run teamviewer .
  • The_Mostwanted
    it kind of magic but i hav no pacman or yaourt , :S any way to install them ??
  • fabrice1
    fabrice1 Posts: 3 ✭✭
    thanks!
  • rowbot
    rowbot Posts: 2 ✭✭
    to resolve this issue i uninstalled and installed version 13
  • mibou
    mibou Posts: 1
    Thank you !!!!! Worked for me.
    Just had to take the amd64 version from : https://packages.debian.org/stretch/amd64/libfreetype6/download
  • engelsp
    engelsp Posts: 3 ✭✭
    Awesome glad it worked.
  • roman13
    roman13 Posts: 2 ✭✭
    Thanks., @kl.
  • Stodatgard
    Stodatgard Posts: 1
    I installed teamviewer version 13: "teamviewer_13.0.6634_i386.deb". There was no "RTlib" in my "/opt/teamviewer/tvbin/" directory so I created one and placed the two 'libfreetype' files there. (One of them was a link to the other one.) Still Teamviewer displays only a empty black window. Rebooted computer, still no luck. Reinstalled, still no luck.
    Most grateful for any help.
  • joaolm
    joaolm Posts: 2 ✭✭
    Man, Thank you very much!
    My TeamViewer 8 wasn't work anymore on my Ubuntu 18.04, I made this changes following your solution:
    1. Create RTlib directory in /opt/teamviewer8/tv_bin/
    2. Copy libfreetype.so.6 and libfreetype.so.6.12.3 to the RTlib directory, as you said.
    3.Edit the file /opt/teamviewer8/tv_bin/script/tvw_config and insert these lines in the beginning
    TV_RTLIB_DIR="/opt/teamviewer8/tv_bin/RTlib"
    LD_LIBRARY_PATH="$TV_RTLIB_DIR"
    4. Run TeamViewer
    And it worked! Thanks again!
  • burzak
    burzak Posts: 3 ✭✭
    But is not destiny to solve this problem to developers directly in a deb-package?
  • joaolm
    joaolm Posts: 2 ✭✭
    I do not know TeamViewer 12, but TeamViewer 8 does not have support anymore, so we need to do the MacGyver way... :)
