connect.teamviewer.com address redirecting
I'm about to start my first session with a client where I will control their system to sort a issue. The Teamviewer support video states that I tell my client to visit connect.teamviewer.com to download the small programe to enable connection. However, when I test the address connect.teamviewer.com all it does it redirect to the Teamviewer homepage. What am I doing wrong?
Many thanks!
  • Hi Esther,
    Thanks for getting back to me so quickly, aporeciated!
  • I know this is an older thread, but thought I would try my luck.
    If I go to get.teamviewer.com, it downloads at 14MB (taking about 90 seconds on the work computer) and then I run it.
    If I go to connect.teamviewer.com, it downloads a similar sized file, but only takes about 5 seconds.
    What is the difference betweem 'get' and 'connect'? And how do I customise my Quicksupport module that it dwonloads the 'connect' version so that clients can access it faster?
    Chris
