Problem with Free license
Loscara88
Loscara88 Posts: 2
Hello i've this problem. I've 1 account  for private use in 2 pc. But in the 2°pc the free version says me the the "evaluation version END IN 7 DAYS".
How is possible?
  • Iain_wels
    Iain_wels Posts: 54 ✭✭
    Hello Loscara88,
    I think you accidentally did apply the trail version of the premium and that is going to expire! You'll need to reach out to the costumers support (or try to redowload it).
    I hope this helps,
    Iain Wels,
    ICT-Support
  • redowloading doenst help so customer support looks to be a safe bet
  • Reyhan
    Dear @Loscara88, dear @adelin
    Thank you for your posts. We need more information to check your issue.
    Please follow this knowledge base article here and fill out the form.
    Thank you in advance.
    Best regards.
    Reyhan
    Reyhan
  • Hello
    i've fill the form, now i'm wainting a reply
    tank you for support
