Can't connect to a remote device
When connecting to a remote device says "ready to connect (secure connection) the following "connect to partner" next to "connection" and that's it...the recording of "identification," no1.jpg2.jpg3.jpg
  • Hello albina,
    Is there a way to put the language in english on your console? Did you look for a popup in gthe background, had that problem a couple of times that a popup pops up behind the application on the home screen.
    I hope this helps,
    Thank you for using teamviewer!
    Iain Wels,
    ICT-Support
  • From the very beginning:
    Partner connected
    I go to the console
    Click the connect button
    then the process is not.
    then to be a process of identification and connection,but about 1:30 in the morning in Moscow, it is not happening
    no pop-UPS no
