How to Resolve Partner ID not connected with router
VishaalJ
in Linux only
Hello ,
I installed teamviewer 12 in fedora linux. But I trying to connect with partner ID - It shows an error that "Partner ID not Connected with router".
Please help to resolve this issue
Hello VishaalJ,
I have a question. Do both parties have internet? If not they should be both connected to the internet.
I hope this helps,
Thank you for using teamviewer!
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0 -
I just got this error after updatong the partner Apple OS to the newest. It shoes as connected in my teamviewer but will not connect with this same error - that the partner may not be connected to the router. ... If it shows as ONLINE, it must be connected to the router
