I can not start a remote control for iphone
gabrielcg
gabrielcg Posts: 1
I'm trying to control my iphone through the computer but I do not find the remote control option
  • Scotty
    Hi Gabrielcg,
    Thanks for your post!
    Unfortunately, at this time TeamViewer does not have the ability to completely control iOS devices the same way as many android devices. As you can see, you can have the remote user take a screenshot that you can view, but there is no "Live View" or remote control functionality at this time due to some restrictions with Apple.
    You can find more information in our FAQ here: https://www.teamviewer.com/en/help/353-How-can-I-control-my-iPad-iPhone-with-TeamViewer
    -Scotty
    Senior Moderator
  • TutorialesPB
    Perú aun a si no deja ser el mejor software de comunicacion remota para pcs , movil y mucho mas !! Team Viewer 12 lo mejor para las empresas .
