How do you change a computer's status to on-line?
Ralph1965
Ralph1965 Posts: 1
I have two computers registered with Teamviewer, my wife's and mine. At times, TV says the status of mine is off-line. How can I get it on-line? Right now I delete it and add it back on. Is there a better way?
Thanks,
Ralph1965
  • Reyhan
    Dear Ralph1965,
    Thank you for your post. I am pleased to see that you are using TeamViewer with your familiy. :smileyhappy:
    Have you installed the fullversion? Could you please check if following setting is set:
    Extras --> Options --> General "Start TeamViewer with Windows"
    I hope this information is helpful!
    Have fun :smileyhappy:
    Reyhan
