Service Fails To Start on Boot (works fine after manual start as ASdministrator)
gt40
Posts: 1 ✭
The service will not start on boot. >> Service is shown as automatic but is stopped immediate after I boot. >> Have enabled it in options but no luck. >> Tried delayed start but no luck >>Have tested service with compatibility tool and rolled back to win 8 but no luck. >>Then after boot if I start manually everything is normal. >> Any ideas what has changed? >>Worked for years just fine. >>This is on Old Dell I5 with Win 10 AE. >> Best Regards
Hi gt40,
Do you still have the issue or is it working again?
Former Community Manager
I face the same issue. I haven't found any solution. Can someone please help? Thank you.
I have the same issue...
In the Windows Event Log there is an error that the TeamViewer service didn't start within 3000 ms.
