FullScreen Not Removing Start Menu Anymore
Hi All
I've been using TM for a long time. However a few days ago it stopped going to proper fullscreen unless I hide the start menu on the host machine.
Any ideas?
Nick
  • jonm
    jonm Posts: 2
    I am also experiencing this with v13 and do not like it. Did you find a solution?
  • nssimpson
    No and it's really annoying. I'm sure that v13 worked at first so this is a new issue.
    Even when I hide the start menu my right hand screen shows it up when I move my mouse to the bottom. (Left hand screen does overlay so this doesn't happen.)
  • jonm
    jonm Posts: 2
    I reverted back to v12 found here (https://www.teamviewer.com/en/download/previous-versions/). That version works fine.
