Installing teamviewer on linaro arm64
PedroPeixoto
PedroPeixoto Posts: 2 ✭✭
Hello
I am trying to install teamviwer 12.0.78 on a small pc with an ArmV8cortex53 processor,  runing an debian based distro (linaro), but i can´t find a way to do it. I already tried the multi architecture with i3386 and armhf and fail to get several dependencies. Is possible to get a installer for this architecture or some instructions to do it ?
Pedro Peixoto
  • PedroPeixoto
    Any ideas ?
  • Telefind
    Telefind Posts: 3 ✭✭
    sudo apt-get update
    sudo apt-get install libqt5gui5 libqt5qml5 libqt5quick5 libqt5webkit5 libqt5qml5 libqt5core5a qml-module-qtquick-controls qml-module-qtquick2 libqt5widgets5 libqt5x11extras5 qml-module-qtquick-dialogs
    wget http://download.teamviewer.com/download/linux/version_11x/teamviewer-host_armhf.deb
    sudo dpkg -i teamviewer-host_armhf.deb
  • Telefind
    Sorry there is a newer version:
    sudo apt-get update
    wget http://download.teamviewer.com/download/linux/version_12x/teamviewer-host_armhf.deb
  • rafael567
    rafael567 Posts: 3 ✭✭
    Dear Telefind,
        I am a team coleague of Pedro Peixoto. I tried exaclaty what you posted, unfortunately after the last instruction appears the following error message:
    "dpkg: error processing archive teamviewer-host_12.1.83885_armhf.deb (--install):
     package architecture (armhf) does not match system (arm64)
    Errors were encountered while processing:
     teamviewer-host_12.1.83885_armhf.deb"
    This is a important issue to us. So additionall help will be very appreciatted.
    Rafael Costa
  • Telefind
    What is the exact hardware?
  • rafael567
    Dear Telefind,
        I am using the following board: DragonBoard 410c Development Board. Please referer to the link below. This board is based on the 64-bit capable Snapdragon 410E processor.
    https://developer.qualcomm.com/hardware/dragonboard-410c
    Rafael Costa
