Parrot OS 3.10/mistake. teamviewer isn't connected to the Internet. debian.
dzod
in Linux only
1.Who was able to install teamviewer on parrot? Without mistakes?
the portable version isn't connected to the Internet. I am a beginner in linux. I do something not so?
*.tar package v13.0.5494 (tar.xz)
https://www.teamviewer.com/ru/download/linux/ 64bit
"Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Starting network process (no daemon)
Network process started (2680)
Launching TeamViewer GUI ...
Yes, that's a bug of the non-installed TAR package, as I have explained here.
I hope we can fix this soon. Meanwhile you could use the installed version.
Linux Developer0
