Ubuntu setup fails at initiating sign in - headless installation
Welcome to TeamViewer configuration.
This short guide helps you to setup TeamViewer on this device. After you have successfully finished the setup, this device will automatically be available in your Computers & Contacts.
Connecting... -
Connecting... -
Connecting... -
Connecting... \
Connecting... \
Connecting... \
Connecting... \
Connecting... |
Connecting... |
Connecting... |
Connecting... |
Connected
Please enter your e-mail / username: ***
Please enter your password:
Initiating sign in
There was a connectivity issue. Please check your internet connection and try again.
boost assertion failed: px != 0 in /mnt/dev/TVLib/TV12/include/boost/smart_ptr/shared_ptr.hpp:typename boost::detail::sp_member_access<T>::type boost::shared_ptr<T>::operator->() const [with T = tvhelper::ISettings; typename boost::detail::sp_member_access<T>::type = tvhelper::ISettings*], line 693
Segmentation fault (core dumped)
my install deatails:
root@flying:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.3 LTS
Release: 16.04
Codename: xenial
root@flying:~# teamviewer version
TeamViewer 13.0.5494 (DEB)
I have installed it by downloading it from the website. Also pretty much all other commands result in a core dump. eg:
root@flying:~# teamviewer service restart
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
Aborted (core dumped)
please whoever wrote me an email about this issue, re-send it as i seem to have lost it when I read it on the phone. thank you
I have the same issue - can anyone post any solution or additional troubleshooting steps?
never got solved. I have even offered to give the core files or remote access to debug. after a few weeks of mailing the support, I have stopped using it.
1
