Teamviewer keyboard issues
zzyo
Hello I've been using teamviewer through the meeting feature, the issue I have is when my partner allows the remote control everything works fine however I use an azerty keyboard and my partner has a qwerty configuration. For typing there is no problem but when I try to use certain softwares or a game itself, the keyboard becomes a mess and I'm unable to properly use certain keys, the same issue happens with the mouse but not as bad as the keyboard. Thanks
1
Hello zzyo,
Maybe it is an idea that you're costumer adds a second keyboard input and when you are connected with teamviewer you switch to the input that you want to use.
I hope this helps,
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0
