Teamviewer 13 repository
rok
Posts: 22 ✭✭
in Linux only
I uninstalled teamviewer 12 from my Ubuntu 16.04 using
sudo apt purge teamviewer
Then deleted forder teamviewer from .config and .local/share (also folder teamviewer12).
Now installed teamviewer 13 using the .deb package. My question is: I just noticed under software and updates/other software there are 4 items:
http://linux.teamviewer.com/deb stable main (ticked)
http://linux.teamviewer.com/deb preview main (ticked)
http://linux.teamviewer.com/deb stable tv13
http://linux.teamviewer.com/deb preview tv13
Should I tick also the last 2 items to get updates from repository?
At this time it's normal, i have same lines on my linux pc's, simply ignore this lines and install your software normally
