Ubuntu 16.04 Server - Teamviewer 12 crashes from time to time
the problem is teamviewer 12 started crashing recently (almost everyday). It happens after some time. Never had this issue with teamviewer11. VNC (other software) is still responsive at this time.
Here are the logs:
2017/01/08 01:55:01.485 9829 4055886656 NX1 SysSessionInfoManager: assigned session 99 to info provider 'None'
2017/01/08 01:55:01.693 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:56:01.713 9829 4074453824 NX1 XSocket observer: adding XSession: 99
2017/01/08 01:56:01.715 9829 4055886656 NX1 XSession[99]: Retrieved XAuth from commandline
2017/01/08 01:56:01.744 9829 4055886656 NX1! VTSessionInfoProvider: Failed setting TTY for session 99 on display ':99'
2017/01/08 01:56:01.744 9829 4055886656 NX1 SysSessionInfoManager: assigned session 99 to info provider 'None'
2017/01/08 01:56:01.963 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:57:01.983 9829 4074453824 NX1!! XSocket observer: stat failed /tmp/.X11-unix/X99, Errorcode=2
2017/01/08 01:57:01.984 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:58:02.004 9829 4074453824 NX1 XSocket observer: adding XSession: 99
2017/01/08 01:58:02.006 9829 4055886656 NX1 XSession[99]: Retrieved XAuth from commandline
2017/01/08 01:58:02.036 9829 4055886656 NX1! VTSessionInfoProvider: Failed setting TTY for session 99 on display ':99'
2017/01/08 01:58:02.036 9829 4055886656 NX1 SysSessionInfoManager: assigned session 99 to info provider 'None'
2017/01/08 01:58:02.254 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:59:01.274 9829 4074453824 NX1!! XSocket observer: stat failed /tmp/.X11-unix/X99, Errorcode=2
2017/01/08 01:59:01.274 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 02:00:01.294 9829 4074453824 NX1 XSocket observer: adding XSession: 99
2017/01/08 02:00:01.296 9829 4055886656 NX1 XSession[99]: Retrieved XAuth from commandline
2017/01/08 02:00:01.327 9829 4055886656 NX1!! XClient fatal XIOError - X server connection lost, Errorcode=11
2017/01/08 02:00:01.427 39 20 GX1 CTcpProcessConnector::HandleRead(): Socket gracefully closed (PID=9829)
2017/01/08 02:00:01.427 39 20 GX1 CTcpProcessConnector::CloseConnection(): PID=9829
2017/01/08 02:00:01.427 39 20 GX1! InterProcessBase::EventFunctionInternal(): IPC-Connection Closed
2017/01/08 02:00:01.427 39 20 GX1 CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 10058: Unknown error
2017/01/08 02:00:01.428 39 20 GX1!! CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 10009: Unknown error, Errorcode=317
$ ./teamviewer
Init...
CheckCPU: SSE2 support: yes
XRandRWait: No value set. Using default.
XRandRWait: Started by user.
Checking setup...
Launching TeamViewer ...
Starting network process (no daemon)
Network process started (18848)
Launching TeamViewer GUI ...
terminate called without an active exception
fixme:nls:GetGeoInfoW -1 4 0x1bedd74 3 0
QMetaObject::invokeMethod: No such method QSystemTrayIcon::isVisible()
fixme:nls:GetGeoInfoW -1 4 0x1cee2ec 3 0
fixme:nls:GetGeoInfoW -1 4 0x1dee2ec 3 0
fixme:nls:GetGeoInfoW -1 8 (nil) 0 0
TeamViewer: Fatal IO error: client killed
fixme:console:CONSOLE_DefaultHandler Terminating process 27 on event 0
Is it something that you are familiar with? How can I help you more to troubleshoot the issue?
flies
Dear flies,
Did you upgrade your TeamViewer 11 to 12 or it was a new installation?
If so, please run these commands to delete any TeamViewer trace, update your system and re-install the software.
cd /
sudo rm -rf /home/*/.local/share/teamviewer* /home/*/.config/teamviewer /opt/teamviewer
cd ~
sudo apt-get update
sudo apt-get upgrade
wget download.teamviewer.com/download/teamviewer_i386.deb
dpkg -i teamviewer_i386.deb
sudo apt-get install -f -yHope that solution works for you.
Christian
Did my reply answer your question? Accept it as a solution to help others, Thanks.0 -
Hi Christian,
thank you for your reply, appreciate it.
Unfortunately - it doesn't apply to my case since I am using standalone version tar.xz inside screen session. There are no leftovers - I have used cleanly unpacked files.
It works fine for a few hours and then stops at some time.
Hi flies,
Make sure you have the latest build of tar.xz
You may check that running the command:
./teamviewer info
Don't forget to run it from the extracted directory.
At the moment this reply was created latest version is v12.0.71510
You may also check the latest build from our website
http://www.teamviewer.com/download/linux
Christian
Did my reply answer your question? Accept it as a solution to help others, Thanks.1 -
Hi Christian,
yes it's the newest one:
[email protected]:~/teamviewer$ ./teamviewer info
TeamViewer 12.0.71510 (TAR_NI)
Newest crash gave other error:
Init...
Checking setup...
Network process started (5810)
Invalid MIT-MAGIC-COOKIE-1 keyterminate called without an active exception0 -
Hi flies,
If you have the latest version, please make sure that all dependencies are satisfied using the following command
sudo ./tv-setup checklibs
The application will give you an example on how to install the missing dependencies.
Christian
Hello again Christian,
everything is intact.
Is there any debug mode I can use to pinpoint the issue or at least allow you to make troubleshooting easier for you?
[email protected]:~/teamviewer$ sudo ./tv-setup checklibs
-=- TeamViewer tar.gz check -=-
In order to use the tar.gz version of TeamViewer,
you have to make sure that the necessary libraries are installed.
NOTE: Most needed libraries are 32 bit libraries, even if you are on a 64 bit system!
Writing raw output to /home/flies/teamviewer/logfiles/DependencyCheck32.log
Writing raw output to /home/flies/teamviewer/logfiles/DependencyCheck64.log
Analyzing dependencies (64 bit)...
All 64 bit dependencies seem to be satisfied!
Analyzing dependencies (32 bit)...
All 32 bit dependencies seem to be satisfied!0 -
Dear flies,
Please try the following command and let us know if this solution works for you.
cd ~/.config
# rm -rf teamviewer
sudo teamviewer daemon restartPlease note that # means that you may need sudo or root permissions.
Hope this solution works for you.
Christian
@flies wrote:Hi,
Here are the logs:
2017/01/08 02:00:01.428 39 20 GX1!! CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 10009: Unknown error, Errorcode=317$ ./teamviewer
Init...
Checking setup...
terminate called without an active exceptionfixme:nls:GetGeoInfoW -1 4 0x1bedd74 3 0
fixme:console:CONSOLE_DefaultHandler Terminating process 27 on event 0Is it something that you are familiar with? How can I help you more to troubleshoot the issue?
Best regards,flies
