How to uninstall TeamViewer Outlook Add-In
Please can you tell me how to uninstall the TeamViewer Outlook Add-In? I don't need it and it is causing outlook to start slowly.
  • Esther
    Hi @Koster
    Did you already try to deactivate it in the TeamViewer settings. Click on Extras --> Options --> Advanced --> Click Show advanced options --> Under More --> Deactivate Outlook Add-In click Deactivate...
    I hope that helps you.
    All the best, Esther
  • Koster
    Koster Posts: 4 ✭✭
    Thank you very much for the clear instructions Esther. i did not know about that setting.
    However, when I go there, it already says 'Activate', suggesting that the add-in is not currently activated. Yet it shows up in Outlook.2018-01-17 11_06_28-Scroll Options.png2018-01-17 11_08_18-Disabled COM Add-ins.png
  • Esther
    Hi @Koster
    Thanks for the update.
    Can you try to do the following in your Outlook:
    1. File --> Option --> Add ins --> Manage: Com Admins --> Go
    2. Find the Teamviewer Meeting Add in --> Highlight and delete
    Looking forward to hear if this resolves the issue for you.
  • Koster
    Koster Posts: 4 ✭✭
    Hi Esther,
    Thank you. I can highlight it, but I can't delete it. (It tried using the delete button and I tried right-clicking, but there is no right-click menu).
    Laurence
  • SkywaIker
    I just renamed the outlook folder, restarted outlook 365 and the plugin is gone :-)
    Thanks for posting that solution.
