Please check your internet connection + no ID
Hi  -
I was using TeamViewer for Business with a recent Company and I am now no longer working for them.  I used TV previously for private use at home.
Now I can't seem to downgrade my license.  When I open TeamViewer it just says "Not Ready Please check your connection" and it gives me no ID and Password.    I've tried uninstalling and reinstalling and I am still getting the same error.
Do I have multiple problems here or is this all account related?
S
  • mLipokmLipok Posts: 766 Star
    This is not related to licensing system.
    EDIT: It was looking like it was not related to licensing system.
    I have active Premium license and currently have the sam problem (just submited error log to HelpDesk ).
    I had similar problem - currently works OK just after restarting system.
    But the main problem was that I try to turn of all AV / FIreWall and also closing runing TV again, nothing was succesfull.
    I already had the same scenario few times.
    Still waiting for response from HelpDesk - about my logs.
    mLipok , AutoIt MVP
  • ScottyScotty Posts: 494 Staff
    Hi sitravelgroup,
    This is license related.
    Can you please contact our support team if you need more information.
    -Scotty
    Senior Moderator
    I just changed my post.
    I apologize for the erroneous diagnosis.
    mLipok , AutoIt MVP
