Use Chrome extension instead of Flash WebConnector
Upliner
I accidentially checked the "Always use Flash Webconnector" checkbox and can't now use Chrome plugin to connect to my computers. How can I reset this setting?
1
Hello!
It is easy, go to Content settings of your browser (for example Chrome) and delete all cookies from teamviewer.com. Then relogin to your Management Console (it will ask you about add your device to trusted again) and push connect. If Chrome extension is installed it wil now open connection in extension.
