Permission to access yum repository denied
in Linux only
The yum repo, that still worked on January 15, 2018, now returns:
Permission to access 'http://linux.teamviewer.com/yum/stable/main/binary-x86_64/media.1/media' denied.
This is the repository as provided by installing 13.0.6634:
/etc/yum.repos.d/teamviewer.repo
I'm getting the same denied message when trying to update through Ubuntu.
what's wrong with that?
@Angelwind: I doubt that. Ubuntu does not have yum. Have a look here.
@Werwolf: did you make any manual changes to the repository configuration? What does 'zypper repos' give you? (Or: which tools are you using?)
@Guus013: Does the problem still exist? Which distribution are you on? Which commands do you use?
Daniel
Only create symlink
ln -s /etc/yum.repos.d/twrepo /etc/zypper/repos.d/twrepo
'zypper repos' output? 'zypper refresh' output?
@DanielStm: I just now added the repo again and it works fine!
I am on openSUSE Leap 42.3 and had simply copied /etc/yum.repos.d/teamviewer.repo to /etc/zypp/repos.d/teamviewer.repo. I use the YaST Software Repositories and Software Management GUIs, which execute zypper commands and zypper read the original yum repo file:
... and updated it to this, I only enabled auto-refresh using the GUI:
pastebin
Same problem here. Command 'zypper refresh' fails!
OS: OpenSuSE 42.3; x86_64
Output of 'zypper refresh teamviewer'
It seems that 'zypper' works slightly different to 'yum' and needs reading permission for some extra files or directories. E.g. Google has managed to set up a repository that functions with both, 'zypp' and 'yum'!!
marcos
@Guus013, @Werwolf, @marcos13: we have released an update.
Please have a look: [Update: 13.1.3026] Spring Update
Please uninstall the current package and replace it with the dedicated SUSE package.
