3 identical computers...2 not online
I have 3 i3's crunching numbers for WCG.
I just switched to 18.3 Mint and now, only the hardlined computer shows online. In fact, I am writing this on a computer that TV is running on but, does not show to be online. My internet connection to the two wireless machine's is strong. All three are fresh install's (OS, BOINC, TV).
All three have 13.0.9865
My laptop, that I monitor these 3 i3's from, all in the same room, next to the router, is using 13.1.1548 and is running Win 8.1.
Even on this computer, that I can remote to my laptop, is shown offline! I cannot remote to this computer from any of them, same thing with the other computer running of wifi.
I had no problems, with this in 12. But my laptop upgraded to 13 and I decided to upgrade the 3 i3 Mint Crunchers so I could remote to them again...13 would not open 12...
I have only 1 monitor for these three machines and primarily remote in to them, now I can only do that with the Lan lined one.
Why are these 2 wifi machines showing as offline, both are currently runing TV with green, "Ready to Connect" Thanks, for any help, in advance.
P.S. I am running the personal use version, and I am a newbie with Linux, for the most part.
  • Arjai
    Arjai Posts: 5
    2018/03/17 12:17:13.652 5510 140264474655872 S! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
    2018/03/17 12:17:13.653 5510 140264474655872 S UpdateOnlineState newOnlineValue 0
    2018/03/17 12:17:13.653 5510 140264474655872 S+ tvnetwork::Offline: online state 0
    2018/03/17 12:17:13.653 5510 140264474655872 S! AsioSettings::FindExternalIP: found 0 external IPs instead of 1!
    This was in the TV Log file on one of the problem pc's
    how do I help it find an external IP?
  • DanielStm
    DanielStm Posts: 224 Staff member ๐Ÿค
    Are all three devices showing different TeamViewer IDs?
    If the status says "green", then they should actually be online. Please update to the latest version. [Update: 13.1.3026] Spring Update
    If that fixes it but the problem comes back, a temporary solution is to restart the background service: teamviewer daemon restart.
    Daniel
    Linux Developer
  • Arjai
    Arjai Posts: 5
    Sorry, but I don't understand.
    How do I do that restart?
    Can I just click that link, while on the linux machine?
    BTW, they are all now hard lined to my new router. still no difference. Next time I will have time to monkey with them is next Monday...
    ย
    ย
  • Arjai
    Arjai Posts: 5
    Yes, all three have seperate ID's
    Laptop is 13.1.369?
    i3's are 13.09865
  • Arjai
    Arjai Posts: 5
    I got one to work. Just need more time to get the others updated. Thanks a lot!!
