IP Addresses
garey
garey Posts: 4
Good afternoon, we use the commercial version tv 10, please notify the list of available global IP addresses with which the program interacts. information is needed to configure the firewall.
  • Reyhan
    Hi @garey,
    Thank you for your post. I recommend you the knowledge base article
    Which ports are used by TeamViewer
    I hope it is helpful for you to configure your settings in your firewall.
    Best regards.
    Reyhan
    Reyhan
  • garey
    garey Posts: 4
    Thank you. But except for ports, I want to also limit access to global IP addresses, is this possible? do you have a list of addresses used?
