QS Add-on for Jiayu S3+
LTH
Posts: 1 ✭
No automatically installed add on.
From Jiayu S3+ all functions do work.
But reverse, the Jiayu S3+ is shown on other Android device, but not responding on mouse clicks...
Which Add-on might be working? (Android 7 does not...)
LTH.
LTH.
Hi there LTH,
Thanks for posting.
In regards to remote controlling of your Jiayu S3+ device, it is most likely that these devices may not support the remote controlling (controlled) function.
This is the case for a few other Android devices where connections and viewing of the screens are possible but the function of being controlled is limited.
Please view the following article in regards to TeamViewer supported devices.
https://community.teamviewer.com/t5/Knowledge-Base/Supported-manufacturers-for-remotely-controlling-Android-devices/ta-p/4730
Thank you once again for posting.
Yuhi0
