Cannot see Audio-on-symbol of my partner
Since a couple of years I cannot see the symbol for "Audio on" on the screen of my TeamViewer-partner. I'm using Version 11 - but also tested V12. So it is not a specific problem of V11.
I can just see a grey area.
Even when I click on the place where the symbol should be – no reaction is following.
My partner must activate his audio – but mine can be heard by my partner immediately.
About 2-3 years before I could see it for a version or two. What can be the reason and how can I fix this problem?
Thanks!
Hi Tatergreis,
Due to security reasons it is not possible to control your partners audio or camera.
Your partner has to do it alone. I will forward your suggestion to our product management.
Julia
Find this helpful? Say thanks by clicking on the Thumbs Up button.5
Hi Tatergreis,
Julia
Find this helpful? Say thanks by clicking on the Thumbs Up button.5 -
Is this still available in any older version? I think you should add this function to advanced options of the program.0
