High cpu usage with TV13.1 on Ubuntu18.04LTS
I know the OS is new and fresh, as is my host CPU i3-8100. Which only recently had some gpu support elements solidifed in the Linux kernel if I understand correctly.
TeamViewer_Desk seems to use a lot, keeping all 4 cores floated upto 40-50% rather than 15-20% with my older slower CPU on Ubuntu17.04.
Known issue being worked on? Others see it? Something that could use a tweak on my end? Any helpful logs I could collect to pass forward?
When the TV square is minimized to the side of the screen, there is a pulsing TV logo... When that logo is pulsing it drives the CPU usage upto 40-50% across all 4 cores. Related to transparency alpha?
Hover curser over the square makes it turn into a static arrow, and cpu usage drops to 3-4%.
@Menel wrote:When the TV square is minimized to the side of the screen, there is a pulsing TV logo... When that logo is pulsing it drives the CPU usage upto 40-50% across all 4 cores. Related to transparency alpha?
Can we get a fix for this piped into a future version? It hammers
Heeeeeelp
Ubuntu 18.04LTS / TeamViewer 13.1.1548 H on amd64
Also Rasbian... same thing and more painful v13.1.1548 H on armhf
nothing? timeline for next TV host upate?
I'm finding **bleep** Connect works much better. Has cloud connect options, 2FA authentication, doesn't have a the large blocky window that takes over raspberryPi. Doesn't trash the CPU.
