Can Chrome OS with TV13 accept incoming connections?
Just wondering. We have clients who want to move their machines to Chromebooks and the Remote Support aspect is a serious setback.
Can Chrome OS with TeamViewer 13 accept incoming connections? It didn't used to, but iOS11 now allows it so I'm wondering if there has been a change to the status of Chrome OS.
Hi AlexFogerty,
Unfortunately no.
Chrome OS currently can only be remote controlled using Chrome Remote Desktop.
You can also find this info under our Supported Operating Systems
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?5
Hi AlexFogerty,
Unfortunately no.
Chrome OS currently can only be remote controlled using **bleep**.
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?5 -
Thanks Scotty.1
Hello @AlexFogerty,
We are happy to announce that you can now share the screen of your devices running ChromeOS. ?
If you want to connect via unattended access, please use the TeamViewer Host.
If you want to connect spontaneously, please use the TeamViewer QuickSupport.You will find the download links here:
Alternatively, you can also download these versions directly on our website here: TeamViewer for Chrome OS
Please also find additional information here: Supported platforms - Chrome OS
