Can sound from Android be played on my computer?
I know that I can play the sounds from another computer on my computer via TeamViewer.
I have got TeamViewer QuickSupport installed on my Android phone. Can the same be done here, that is, can I hear sound from Android on my computer? And can I do the vice-versa also? If yes, how?
  • evjpjr
    evjpjr Posts: 1
    thank u.
    solved
  • gockel
    gockel Posts: 1
    are there any news about the issue?
    BR
    gockel
  • rhettorical
    Is there any update on this? I see that the option to share audio is still greyed out so I assume it's not been added as a feature yet, but is it in the works at all?
