team viewer installation problem
ekkkko
Posts: 1 ✭
hello, so after after the latest update my tv doesnt work and when try to acces tv this message appears: "Windows cannot access the specified device, path, or file. You may not have the appropiate permissions to access the item. so after this i unistall my tv and try to install again but at the end of installation this message appears: "The TeamViewer could not started. The installation will be continued."
i really apreciate if you could help me, ty
Has anyone found a solution to this issue?
