How to Install TeamViewer on Mac?
We have a couple Mac computers in our corporate environment and have not yet installed TeamViewer on them. I have an appointment tomorrow with 2 of the people who have Macs and am wondering how I am going to get TeamViewer insatlled and running on their computers.
I am presuming that the install executables we use for the Windows computers will certainly not work for the Macs. So, how do i go about getting a Mac install file?
I have scoured the TeamViewer site and management console for any hint of how to buildout the executable installation file but have found nothing. Any insight?
  • Esther
    Esther Posts: 4,112 Former Community Manager
    Hi @MarkVergara
    Thanks for your post.
    If you would like to install TeamViewer on the Mac, you can find the right download packages here: Download TeamViewer for Mac
    On this page you´ll find the TeamViewer full version as well as the Host module and the QuickSupport and QuickJoin module.
    If you wonder which module fits best for your needs, you can have a look into this article in which we explained the different module: TeamViewer modules
    I hope this helps you.
    All the best, Esther
  • I didn't quite clarify the issue so my apologies. The issue is we have a corporate account and I need to get our installer setup unattended access for 2 Mac computers. I am meeting remotley with the 2 users tomorrow and will have to either push the installer out to them using another tool (LogMeIn) or hopefully be able to download an unattended access installer for Mac.
    Since I do not have a Mac computer to do any testing I cannot verify anything until I work the users tomorrow. I am guessing the option provided is not what I need. Is this correct?
  • Esther
    Hi again @MarkVergara,
    Thanks for getting back so quickly.
    Maybe this article helps you, if you are ok with deploying the TeamViewer Host: Script based Host deployment on macOS
    I need to update the article because it says TeamViewer 12, but it is also valid for TeamViewer 13.
    Hope this helps you,
    Esther
  • Thanks for the scripting which looks like it would work; however I assume I do not have sufficient privileges to be able to get to the following:
    link-to-your-custom-host-module
    link-to-the-assignment-tool
    API-token-of-your-host-module
    I have scoured my entire Tean Viewer managment console and it would seem I should be able to find those in the "Design & Deploy" area of it. I am met with an "Insufficient permissions" message when attemopting to access that area.
    I suppose this will have to be escalated to our IT Director as I believe he is the only one with such permissions
