Accidentally Displayed ID and Password in Public Livestream
I just did a public livestream on YouTube where I accidentally showed my ID and password to the rest of the world.
I reset my password already but now both the ID to my laptop and my desktop are available to the public. Is there anything I can do to change the ID or add an extra layer of security?
  • Julia
    Julia Posts: 290 Staff member ๐Ÿค
    Dear ItsCheif,
    It is not possible to change the TeamViewer ID. Good, that you already changed the password
    I recommend you to activate a whitelist on the device under "extras - options - security".
    You can put your account on the whitelist and after doing that, the only one who can reach your machine is the account from the whitelist.
    Cheers,
    Julia
