Licence needed??? for Free user?
kadabra
Posts: 1 ✭
i´ve actually the problem that i can´t access to my Home PC at a Company PC.
i´m doing no business in this case. i only connect from Work PC to my Local home pc to check something but now the problem is that i´m loosing every time the connection and teamviewer is telling me that i´m using for Business and need a key. but this is not correct. i never used Teamviewer to connect to my Work pc oder something else.
best regards
We keep getting this message as well, we are about to quite Team Viewer anyway since they no longer have the touch support for windows. Makes it impossible to use on a surface pro
