Remote Control + Meeting with Windows 10
SamStamport
When using Remote Control is it possible to have a live conversation/meeting using headphones with the other person?
Hi SamStamport
Thanks for posting!
Yes! this feature can be accessed through the menu while making a connection under "Communicate". Here you can start voice calls, video streams and also chats with the remote side.
I hope this helps!
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?0
