I'm connect from a macbook pro to a linux machine (ubuntu). When trying to use vscode on the remote machine, it seems that I cannot forward any key combinations that include a modifier + a symbol key
For example, if I try to set something like
ctrl+/
alt+/
alt+[
the modifier press is registered but the symbol key doesn't. Pressing a letter key instead of a symbol key works fine, enabling forward key combination does not affect this (only thing it does is send alt from the command key instead of sending it from the option key, either way, either the option or the command keys are disabled).
Any ideas?
