where is my password on ipad?
Hi KathyW
There is no password for the iOS QuickSupport App.
You just connect with the TeamViewer ID and there will be a prompt on the mobile to let you in.
Also note you cannot connect to the "TeamViewer for Remote COntrol" app. This is only for controlling other devices.
On iOS you must use the QuickSupport App.-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?0 -
Thank you. I played with it some more and understand it a little better now.
