SOS button doesn't work after restart
When I create a QuickSupport module with an SOS button added into it, Teamviewer creates a folder into C:\Users\%username%\Local\TeamViewer\CustomConfigs\
beause of this the SOS-button goes to:
C:\Users\%username%\Local\TeamViewer\CustomConfigs\<ID>\TeamViewer.exe
After a reboot of the system however, Teamviewer.exe is removed from this directory, while every other single file stays intact.
Prior to system reboot.
Then, after the system has rebooted, I want to start again via the SOS button, I recieve the following error, and with the folder opened I see the following:
After system reboot, file missing, and the shortcut doesn'have a destination anymore.
I have the same problem, identified the cause?
I have the same problem! It happens really often! Can somebody help or have an explanation for that??
Same Problem. Have to reinstall every time on Windows 10
I have the same issue. Teamviewer, is there a fix for this yet?
Same here. Any one from teamviewer to help?
