teamviewer 13.2.13582 crashes on connect (kubuntu 16.04.4 to WIN10)
I tried posting this already and seems not to be on system ???
I believe that the problem I have requested help on is found as follows:
I did a search for the required libraries in Teamviewer 13.2.
First I ran
/home/user$ sudo ldd /opt/te > tv.txtamviewer/tv_bin/TeamViewer | awk '{ print $1 }' > tv.txt
this gave me the list teamviewer expects
then I made a file tvSEARCH.sh
#!/bin/bash
while read -r FILE
do
FOUND="$(find . -name "$FILE" -print -quit)"
if [ "x$FOUND" != "x" ]
then
echo "FOUND: $FILE"
else
echo "NOT FOUND: $FILE"
fi
done <tv.txt
I then made it executable with
chmod 777 tvSEARCH.sh
I then ran it with
$ ./tvSEARCH.sh
this provided the following:
NOT FOUND: linux-vdso.so.1
NOT FOUND: libdbus-1.so.3
FOUND: librt.so.1
FOUND: libdl.so.2
NOT FOUND: libQt5WebKitWidgets.so.5
NOT FOUND: libQt5X11Extras.so.5
FOUND: libQt5DBus.so.5
NOT FOUND: libQt5WebKit.so.5
NOT FOUND: libQt5Quick.so.5
NOT FOUND: libQt5Qml.so.5
FOUND: libQt5Widgets.so.5
NOT FOUND: libQt5Network.so.5
FOUND: libQt5Gui.so.5
FOUND: libQt5Core.so.5
FOUND: libm.so.6
FOUND: libpthread.so.0
FOUND: libc.so.6
NOT FOUND: /lib64/ld-linux-x86-64.so.2
NOT FOUND: libsystemd.so.0
FOUND: libQt5PrintSupport.so.5
NOT FOUND: libQt5OpenGL.so.5
FOUND: libstdc++.so.6
FOUND: libz.so.1
NOT FOUND: libXrender.so.1
NOT FOUND: libXcomposite.so.1
FOUND: libjpeg.so.8
NOT FOUND: libpng12.so.0
FOUND: libX11.so.6
NOT FOUND: libxslt.so.1
NOT FOUND: libxml2.so.2
FOUND: libglib-2.0.so.0
FOUND: libgobject-2.0.so.0
NOT FOUND: libgstreamer-1.0.so.0
NOT FOUND: libgstapp-1.0.so.0
NOT FOUND: libgstbase-1.0.so.0
NOT FOUND: libgstpbutils-1.0.so.0
NOT FOUND: libgstvideo-1.0.so.0
NOT FOUND: libgstaudio-1.0.so.0
NOT FOUND: libsqlite3.so.0
NOT FOUND: libicui18n.so.55
NOT FOUND: libicuuc.so.55
NOT FOUND: libQt5Sql.so.5
FOUND: libGL.so.1
NOT FOUND: libdouble-conversion.so.1
NOT FOUND: libproxy.so.1
NOT FOUND: libharfbuzz.so.0
FOUND: libgcc_s.so.1
NOT FOUND: libpcre16.so.3
NOT FOUND: libselinux.so.1
NOT FOUND: liblzma.so.5
NOT FOUND: libgcrypt.so.20
FOUND: libxcb.so.1
FOUND: libpcre.so.3
FOUND: libffi.so.6
NOT FOUND: libgmodule-2.0.so.0
NOT FOUND: libgsttag-1.0.so.0
NOT FOUND: liborc-0.4.so.0
NOT FOUND: libicudata.so.55
NOT FOUND: libexpat.so.1
FOUND: libxcb-dri3.so.0
FOUND: libxcb-present.so.0
FOUND: libxcb-sync.so.1
FOUND: libxshmfence.so.1
FOUND: libglapi.so.0
FOUND: libXext.so.6
FOUND: libXdamage.so.1
FOUND: libXfixes.so.3
FOUND: libX11-xcb.so.1
FOUND: libxcb-glx.so.0
FOUND: libxcb-dri2.so.0
FOUND: libXxf86vm.so.1
FOUND: libdrm.so.2
NOT FOUND: libfreetype.so.6
NOT FOUND: libgraphite2.so.3
FOUND: libgpg-error.so.0
FOUND: libXau.so.6
FOUND: libXdmcp.so.6
The large number of NOT FOUND libraries is astounding.
What do you suggest?
Do I need to compile from source to do this? If so, is source available?0
Ran against an updated win 10 machine (this morning for win 10 updates) in my home and it works fine. Will run against a PC win 10, 450 miles from here tonight. See if that works also.
