Upside down remote screen
Baronman
Posts: 1 ✭
On many occasions the remote screen is displayed upside down. I cannot find a way to flip it vertically so that it is up the correct way. Is there any reason for this to happen?
Hi @Baronman,
I think it has to do with the ability to send, receive keystrokes.
If your interlocutor has a Windows system and can receive key combinations, you can try CTRL + ALT + UPRegards.
Domenico Langone
1
