I need to report unlicensed use of TeamViewer -- but I am not eligible to use the ticket system.
mwhowell87
I need to report unlicensed use of TeamViewer. But I am not eligible to use the ticket system, since I don't have a license myself.
I worked at a company called [Removed By Moderator]. From 2015 to 2017, I remember this company using TeamViewer without a license. I also used this program without a license, as part of working for [Removed By Moderator]
This is a confession that I wish to make. I would much appreciate someone forwarding this message to the appropriate authorities. This is the closest I can do to sending a ticket.
Thank you.
Thank you very much for your honesty @mwhowell87
I will make sure to follow this up, but I removed some details due to privacy concerns.
ScottySenior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?0
