Display doesn't sleep on Mac after accessed by Teamviewer
Hi folks. I'm using an iMac with teamviewer and every time I connect I notice when I get home the screen is still on and it never goes off. This is only because of teamviewer as I have the display set to turn off after 3 minutes. I just installed teamviewer a few days ago and this has happened ever since. Help needed. Thanks.
I'm having the same issue when logging into my iMac from my Macbook Pro using v13.2.14328.
Once logged out without not locking my iMac, the screen doesn't go black after a minute as per set. In order for me to get my iMac's screen to go black, when ending a session, I have to click Action tab > Lock Computer > Lock On Session End. Then after a minute, my iMac's screen does turn off. But I have to log back into it each time access it though. Is there a way to keep from having to do that?
